Is anybody else having problems with lip sync in TrueHD? I didn't try TrueHD until I got the 2.0 FW (which has been working fine for me otherwise). The only title I have with TrueHD is Constantine. When I play it with TrueHD, the sync is definitely off. If I switch back to DD+, the sync is good again. I've tried pauses and other operations to help it find sync again, it seems to stay quite consistent.
Originally Posted by plazman
I am assuming you are using analog and not digital/coax for audio.
I've had no problems, so maybe try rebooting a couple of times. May help....
Yes, I meant to say I was using analog. I've powered down and back up a few times since the upgrade, that would reboot the machine, I would think...
Thanks for the feedback though, sounds like it's something in my setup. Maybe it's just my Constantine disc, when I get a different disc with TrueHD, I'll try that.
Actually, powering up and down is just kind of like "standby." For a full reboot, hold the power button down until the machine resets.
I did have dialogue enhancement off, but thanks for the suggestion. I need to try rebooting, do you hold down the power button from a power on or off state, or doesn't it matter?
I'm not going to worry about it too much until I get another TrueHD title and see if it does the same thing. Sounds like I'm not the only one seeing this on Constantine but maybe it's an unusual problem.
Originally Posted by thebland
Why not use the lipsync control on your processor / receiver? . That's what it is there for...
Glad to see that HDMI is a non-issue with this.
I don't think my receiver has anything to help with the analog inputs (Pioneer 815). Not a big deal, if the sync bothers me enough I can use the DD+, just thought I'd see if this was common or not...
Doesn't appear to be common, this is the first I've heard of it. My setup does not suffer from this problem.
I updated my player to 2.0 last night and spun Constantine, I had an uncorrectable lip-sync issue with TrueHD. I did not try DD+ or spin Phantom to see if it's there as well.
Hmm, I just watched this yesterday with no problems with either track (started out in DD+ on accident).
I rented Constantine 2 nights ago. I played it on my 360 and also noticed some slight lip sync issues. I put it in the mail and forgot to try it out on my A1. Guess I'll have to run out and buy it.
Just with TrueHD, or with both tracks?
I'm getting it with Batman Begins, mainly with the TrueHD track.
I noticed significant lip sync problems with "grand Prix" hd-dvd. To my eyes and ears the voices are delayed compared to video. It was so noticeable to me that i thought i was watching a dubbed foreign film. I can understand, however, how many would overlook it if they were not paying close attention. According to review of this hd-dvd at high-def digest website this movie has "dolby digital plus" soundtrack only. Their review makes no mention of audiosync problems, which makes me suspect that the 360 add-on is the culprit. Unfortunately, I do not possess a stand alone hd-dvd player to do a/b comparison. FWIW i am using official xbox 360 hd/av cable with optical into a yamaha receiver. sony 32" xbr1 lcd.
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
