Paradigm Owners Thread
16 reading
5M views 43K replies 3.7K participants last post by  HDVidGuy
#1 ·
I'm curious, What Paradigm speakers do you use in your setup? What do you use to power them? What components do you use with them ie CD player, DVD, DAC's etc. Is your room acoustically treated? Are you pleased with your speakers in your setup? Did your Paradigms meet your expectations?
I'd like to hear from other Paradigm owners, and their opinions!
I have the Signature S2's as my dealer recommended for my size room being 11' x 12'. I have the Birdseye Maple Series. I have the S2's on sand filled Premier J29 stands, I have the C3 Center in a oak cabinet directly above my Sony XBR, I use a Veloydyne HGS sub in the right corner. Currently I'm using my left-over B&W wall mounted speakers direct firing on side walls facing the listening position. (My SIgnature ADPs should be here this week to replace the B&Ws.
I'm using an Arcam AVR300 to power the 5 speakers, the sub of course is self powered. I purchased a Arcam DV29 for DVD's and DVD-a multi-channel music, for two channel music I purchased an Arcam CD33, WOW...what a CD player
I use the DV29 for DVA-a discs, and even though i've yet to tweak the settings, when I'm in my listening position I'm stoked by the multichannel disc play...This is my first experience with DVD-A ...Didn't even know what it was a few weeks ago. After listening to it I've already bought several good DVD-As I'm blown away with the separatiion and music/vocal qualities, the Arcam DV29 does an better than admirable job at 6ch analogue....certain old DVD-A CDs blow me away...Steely Dan, Santana Supernatural, Weather Report, Fleetwood Mac, Led Zeplin...just to name a few. Excellent sonic separations into the channels.
...Not to get off track, My Signatures are new and I'm playing them constantly with all different kinds of music, and I've noticed a slight characteristic change with them, the are getting (I'n my amatuer descriptions) much clearer, I guess the higher frequencies, the mid range is getting deeper and tighter, and they seem to open up the soundstage to place instruments and vocals in different locations, I guess where you would expect them to be on stage in a live performance. I close my eyes sometimes just to imagine where each sound is comin from....they do that, they place where the sound originates from. Womesn vocals are excellent BTW..
Aside from Multichannel, two channel direct is superb!
I guess what I'm trying to convey is that I'm extremely pleased in my gear choices with the help from my salesman...The best I've heard in my home to date. My salesman wants to come over and further tweat it when I get the ADP's.
I'm sure that there is the "step-above-audio-crowd" with better gear and higher quality speakers, and way more expensive equipment than I have that could shame my setup...but in defense, this setup is the best I can afford pressently and I'm ecstatic
I'dlike to hear from other Paradigm owners and their setup, and how they think the Paradigms integrate into their systems? Love to hear some feedback
Oh, and one final question??? What are the dimensions of your listening room? Thanks...
#42,821 ·
I have the sub2. Absolutely shakes my house and it’s in my basement, it shakes my front outside concrete driveway. I would think paradigm may have specials on it. Since it’s sealed, I find that it’s super tight. Others will comment otherwise.
Are you running it 240 or 120v. Quote from a Sound and Vision article
"What I heard with my 120-volt service left me scared ****less to hear what this thing would sound like with 240 volts."
#42,822 ·
Yes fully dedicated 240v. Initially I used 120, the change to 240 was substantially better.
#42,824 ·
I highly doubt that 120v peak 3000 watts was ever fully realized. What is the amperage of the 240v circuit you installed.
15amp
It’s class D amp, not AB.
I had 120v 20amp circuits for the rest of my system. Dedicated circuits for each 28 cubed. The overall cost was just an increase in wire costs. All done before drywall went up.
